This procedure shows how to configure Simplified vIST in an SMLT
environment. It includes steps to configure the following:
Important
            When you enable Simplified vIST with the virtual-ist enable
                command, two VLANs are automatically created to support vIST. The VLAN IDs are: 4086
                and 4087.
            SPBM must not be enabled on the vIST peers.
Important
                Do not change the system MTU to less than the default value of 1950 bytes. The
                    system MTU must be 1950 or jumbo because of a header size increase.
                In the navigation pane, expand
                Select the Boot Config
                    tab.
                Clear EnableSpbmConfigMode to disable the boot flag.
                    The system responds with the following messages:
                    Warning: Please
                            save the configuration and reboot the switch for this to take
                            effect.
                    Warning: Please
                            carefully save your configuration file before rebooting the switch.
                            Saving configuration file when spbm-config-mode is changed to disable,
                            removes SPBM configurations from the configuration
                        file.
                Select Apply.
 - Save the configuration, and then reboot the switch.
Important
                        A change to the EnableSpbmConfigMode boot flag requires a reboot for
                            the change to take effect.
                Configure the SMLT MLT:
                        Expand .
                        Select MLT/LACP.
                        Select the MultiLink/LACP
                                Trunks tab.
                        Select Insert.
                        In Id, type
                            the ID number of the MLT.
                        In PortType,
                            select access or
                            trunk.
                        In Name,
                            type a name for the MLT, or accept the default.
                        In PortMembers, select the ellipsis (...).
                        In Port Editor:
                                PortMembers dialog box, select the desired ports.
                        Select Ok.
                        In VlanIdList, select the ellipsis (...).
                        In VlanIdList dialog box, select the desired VLANs.
                        Select Ok.
                        In MltType,
                            select splitMLT
                        Select Insert.
                            The switch adds the SMLT MLT to the MultiLink/LACP Trunks tab in the
                                MLT_LACP box.
                Configure the vIST MLT:
                        Repeat steps 6.a to 6.o to configure the MLT.
                        Select
                                virtualIstMLT to enable Simplified vIST.
                        Select Insert.
                Create the vIST  VLAN:
                        Expand .
                        In Basic,
                            select Insert.
                        In Id, type
                            an unused VLAN ID, or use the ID provided.
                        In MstpInstance, select the down arrow, and then choose an
                            MSTI instance from the list.
                        In Type,
                            select byPort.
                        In Port Editor:
                        Select OK.
                        Select Insert.
                        Select the vIST VLAN
                            from the list of VLANs, and then select IP.
                        Select Insert.
                        Configure the IP address
                            for the vIST VLAN.
                Repeat step 8 to create an SMLT VLAN and assign the SMLT MLT ID to it. Do not use the vIST
                    MLT ID.
